could i use SLAM with one camera only?
Originally posted by noonv on ROS Answers with karma: 471 on 2011-02-16
Comment by phil123456 on 2020-02-19:
"feasability" is not your only concern
you got stereo systems that use the depth of each pixels (from intel realsense) and yet these system sometimes fail to SLAM with 100% accuracy
so I doubt one camera will give you reliable results
4 Answers 4
It's possible, but a bit more complicated than using two cameras. You are essentially using parallax in time (the camera position at one instant, and then the camera position at the next instant) to do feature recognition and localization.
Two resources for this come to mind:
  1. SLAM with a Single Camera, Davison 2002. I think that he has a bit more information on his own personal website.
  2. MPRT's kinect-3d-slam. I believe that this is also using the point cloud capabilities of the Kinect in addition to the vision data. ROS source code is available on their website, though, so it might be a good place to start work.
Originally posted by mjcarroll with karma: 6414 on 2011-02-16
Post score: 7
Comment by noonv on 2011-02-17:
Thank you for very detailed answer!
Comment by KOMODO on 2020-06-29:
links are death
You might be interested in Hauke Strasdat's work: http://www.ros.org/wiki/ScaViSLAM
It's not released yet, but should be soon.
Originally posted by Felix Endres with karma: 6468 on 2011-02-16
Post score: 4
Great video! Thank you!
And also RGBD-6D-SLAM (for kinect), as well as MonoSLAM (for a normal camera)
You can also look at:
