So imagine this scenario:
You are driving you car towards a red stop light. As a human, you would naturally adjust your speed so that you smoothly stop in front of the stop line.
Here is how a PID controller would do it:
P: The proportional part of the controller would measure the exact distance from the car to the stop light, and drive slower and slower as it approaches the light. The P-controller will drive super slow when getting close to the light, eventually stop without actually reaching it.
I: The integral part of the controller would go fast towards the light, pass it, realise it had gone too far, drive back, drive back too far, then go forwards again, drive pass the light again, and so on. The I-controller might, in fact, never stop on the line.
D: The derivative part of the controller would know exactly when to start breaking, so that it does not break to early - like the P-controller - nor does it drive to far - like the I-controller. Instead, it would start breaking exactly when it needs to, giving a firm but smooth stop in front of the stop light.
A properly tuned PID would combine these characteristics: The P would measure the exact distance to the light, and adjust the initial speed according to this distance. The I would be more aggressive, and enforce that no breaking is done until the the stop light is close, while the D would take over breaking when it realises the car is going way too fast towards the stop light, and break firmly.
Depending on the weighting of Kp, Ki and Kd, these characteristics will be more or less visible in the final system. Of course, the example contains some simplifications. For a general tuning guide, have a look at the Ziegler-Nichols method; the first paragraph in this wiki pretty much explains it all. Note that this tuning method is merely a guide, and that you will most likely have to manually fine tune the system afterwards.
Hope that helps!
