Gazebo Answers logo
Problem
Starting a demo world in Gazebo 11 by using
gazebo --verbose /opt/ros/foxy/share/gazebo_plugins/worlds/gazebo_ros_depth_camera_demo.world
causes all topics to appear as expected when checking with ros2 command line tools. Even when echoing the topics I can see the messages containing actual, seemingly plausible data.
However, when using a custom written script (C++, see below) to subscribe to the topics, only some of the topics published by the demo worlds are actually received. The subscription process works correctly, at least the subscriber count of each topic increases when starting the script. But receiving a message/invoking the callback function works only on few topics.
Specifically the topics /demo_cam/mycamera/depth_cam_info_demo and /demo_cam/mycamera/raw_cam_info_demo, both of type sensor_msgs/msg/CameraInfo, show different behaviour. Subscription to both works, but only ever the depth_cam.. topic triggers callbacks (regardless of which subscriber in the code is set to it, even both at the same time work).
I encountered this problem while running a custom .sdf model that publishes a pointcloud2 by using the libgazebo_ros_ray_sensor.so plugin. Using the cli tool the messages appear to be plausible and containing data. But when trying to visualize it in rviz2, it does not show, but also does not throw any errors (neither tf nor topic errors). Triggering the callback for this topic in a custom script does not work either.
Is it likely that these discrepancies between topics of the same type are caused by configurations on my system? Would Gazebo 11 from source be a better option? Any ideas how I could investigate this problem further, since I do not know if it is related to ros2, gazebo, or some middle ware communication? Thanks for any helpful tips.
Edit: Apparently another user experiences same symptoms with /imu messages published by a gazebo model and asked a question over at ros forum. But I am not sure whether these issues are caused by ros or gazebo.
Setup
  • Ubuntu 20.04
  • ros2 foxy installed as package ros-foxy-desktop
  • gazebo 11 installed as package ros-foxy-gazebo-ros-pkgs
  • script to test whether messages are received (compiled in a colcon workspace):
    #include <functional>
    #include <memory>
    #include <string>
    #include "rclcpp/rclcpp.hpp"
    #include "std_msgs/msg/string.hpp"
    #include "std_msgs/msg/float32.hpp"
    #include "sensor_msgs/msg/point_cloud2.hpp"
    #include "sensor_msgs/msg/camera_info.hpp"
    #include "sensor_msgs/msg/image.hpp"
    #include "nav_msgs/msg/odometry.hpp"
    #include "gazebo_msgs/msg/contacts_state.hpp"
    working topics so far:
    /odom - odometry (ackerman, diff drive)
    /distance - float32 (ackerman)
    /depth_cam_info_demo - sensor/CameraInfo (depth cam demo)
    /points_demo - PointCloud2 (depth cam demo)
    not working topics:
    /bumper_demo - gazebo_msgs/contactsstate (bumper demo)
    /pointcloud2 - pointcloud2 (sensor in sdf model)
    /camera_info - sensor/CameraInfo (cam demo)
    /image_raw - sensor/Image (cam demo)
    /raw_cam_info_demo - sensor/CameraInfo (depth cam demo)
    /image_demo - sensor/Image (depth cam demo)
    /depth_demo - sensor/Image (depth cam demo)
    typedef sensor_msgs::msg::CameraInfo custom_type_one;
    typedef sensor_msgs::msg::CameraInfo custom_type_two;
    const std::string topic_one = "demo_cam/mycamera/depth_cam_info_demo";
    const std::string topic_two = "demo_cam/mycamera/raw_cam_info_demo";
    using std::placeholders::_1;
    class ReBroadcaster : public rclcpp::Node
    public:
    ReBroadcaster() : Node("rebroadcaster"), count_(0)
    subscription_ = this->create_subscription<custom_type_one>(topic_one, 10,
    std::bind(&ReBroadcaster::topic_callback_one, this, _1));
    subscription_two = this->create_subscription<custom_type_two>(topic_two, 10,
    std::bind(&ReBroadcaster::topic_callback_two, this, _1));
    RCLCPP_INFO(this->get_logger(), "Constructed subscribers!");
    private:
    void topic_callback_one(const custom_type_one::SharedPtr msg) const
    const custom_type_one::SharedPtr a = msg;  // just so there is no unused var warning
    RCLCPP_INFO(this->get_logger(), "Got one!");
    void topic_callback_two(const custom_type_one::SharedPtr msg) const
    const custom_type_two::SharedPtr a = msg;  // just so there is no unused var warning
    RCLCPP_INFO(this->get_logger(), "Got ---TWO!");
    size_t count_;
    rclcpp::Subscription<custom_type_one>::SharedPtr subscription_;
    rclcpp::Subscription<custom_type_two>::SharedPtr subscription_two;
    }; // end of class
    int main(int argc, char * argv[])
    rclcpp::init(argc, argv);
    rclcpp::spin(std::make_shared<ReBroadcaster>());
    rclcpp::shutdown();
    return 0;
Originally posted by reza on Gazebo Answers with karma: 11 on 2020-09-28
Comment by MichaelSprague on 2020-10-08:
I have not been able to get a depth camera sensor working in Gazebo 11 either. Even using the Gazebo provided world and no ROS plugins. I do have a standard camera and laser scanner working, so I think something is wrong with the depth camera in the current version.
~$ gazebo --verbose ./depth_camera.world
Gazebo multi-robot simulator, version 11.2.0
[Wrn] [msgs.cc:1842] Conversion of sensor type[depth] not supported.
Comment by Angrybearr on 2020-10-27:
I am experiencing very similar behavior, no visualisation in rviz2, for anything.
Gazebo Answers logo
My problem was solved by an answer to a similar problem of another person over at ros forum.
Basically the QoS of the subscriber/publisher pair is not compatible as described here.
Check QoS of a topic with
ros2 topic info -v /topicname
Setting the right QoS for the subscriber (in this case reliability='best effort' is needed) in the custom c++ script by using
create_subscription<custom_type_two>(topic_two, rclcpp::SensorDataQoS(), std::bind(...));
and setting the QoS in rviz2 in the individual topic settings solves the problem.
Originally posted by reza with karma: 11 on 2020-11-16
