So I need to output a varying voltage off an Arduino Mega in a range of 17 to 32 millivolts, which I've attempted to do by sending a PWM signal off the board into a low-pass filter which steps down the voltage.
This works, but the problem is that Arduino's analogWrite function accepts a value of 0 - 255 to represent the duty cycle of the PWM which isn't precise enough. A value of 1 yields around 20 millivolts and a value of 2 yields around 40 millivolts. Is there some way to have a duty cycle that is more precise than the 0 - 255 range like 0 - 1023 (I think even this isn't really precise enough)? Or is there a better way to get precise voltage output?
The mega is running on and outputting a max voltage of 5 volts, and the low pass filter contains an 11 kiloohm resistor and a 1 microfarad capacitor.
