Gazebo Answers logo
I noticed in the SDF specification one can add a <shader> tag with type normal_map_tangentspace to a <material> tag. But when I try to load my world file in gazebo 9 (also tried it in 7), the last output I get in the console is waitForService: Service [/gazebo/set_physics_properties] has not been advertised, waiting.... It will wait forever.
I also made sure that the gazebo_model_path is set up correctly in my package.xml, so the texture file specified in the <normal_map> child tag should get found. It works at least for meshes and material scripts. Here is a snippet from my world file:
    <model name="model">
        <link name="link">
            <visual name="visual">
                <geometry>
                    <mesh>
                        <uri>model://mesh.dae</uri>
                    </mesh>
                </geometry>
                <material>
                    <shader type="normal_map_tangentspace">
                        <normal_map>model://materials/textures/Normal.png</normal_map>
                    </shader>
                    <script>
                        <uri>model://materials/scripts</uri>
                        <name>Material</name>
                    </script>
                </material>
            </visual>
        </link>
    </model>
Does anyone have experience with this and knows what I'm missing?
Thanks in advance, David
Originally posted by D4KU on Gazebo Answers with karma: 1 on 2018-10-18
Comment by chapulina on 2018-10-18:
That console message seems to be coming from ROS and not related to Gazebo's rendering.
Also, I'd double-check that you're referring to the correct resource locations, usually you'd have the model name after model://
Comment by D4KU on 2018-10-22:
I'm pretty confident that the path is correct. I've tested it by using it in the mesh uri as well. The mesh got found after I copied it to the same location as my normal map image. And I double checked its name a 1000 times. I had the hope that the last output would give someone a hint where gazebo or ROS seem to encounter a problem. Sadly I have no other feedback, since there is no exception being thrown or anything. It just works fine as soon I comment out the tag in my world file.
Gazebo Answers logo
I figured it out. I copied 'normal_map_tangentspace' from the SDF specification, but it's a typo. It must say 'normal_map_tangent_space'. That little thing has cost me hours...
Originally posted by D4KU with karma: 1 on 2018-12-20
