Gazebo Answers logo
I created a simple .world file:
<?xml version="1.0"?>
<sdf version="1.4">
    <world name="office">
        <include>
            <uri>model://sun</uri>
        </include>
        <include>
            <uri>model://ground_plane</uri>
        </include>
    </world>
</sdf>
My launch file also adds a robot to this world. It launches fine in gazebo, I can see the gray ground plane with grid markings on it and also my robot. image description
Next I created a simple building layout (some walls created using Gazebo's building editor). I saved the building model and added these lines to my .world file:
<include>
    <uri>model://car_description/models/tunnel</uri>
    <pose>25 20.2 0 0 0 0</pose>
</include>
When I launch the file again, this time it takes ages to launch. I see a 'Preparing your world ...' screen for a long time (~10 mins): image description
and then I see this dark screen:
image description
Other solutions which I have tried and did not work for me are:
  1. Adding the following code to the package's package.xml
     <export>
        <gazebo_ros gazebo_model_path="${prefix}/models"/>
           <gazebo_ros gazebo_media_path="${prefix}/models"/>
     </export>
  2. Adding the environment variable GAZEBO_MODEL_PATHto my .bashrc file:
     export GAZEBO_MODEL_PATH=/home/my_user/my_catkin_ws/src/
There are no errors thrown in the terminal. What am I doing wrong?
Originally posted by Subodh Malgonde on Gazebo Answers with karma: 31 on 2018-08-11
Gazebo Answers logo
I placed the model files in the ~/.gazebo/models directory and changed the code in the .world file to:
<include>
    <uri>model://tunnel</uri>
</include>
Its working fine now. However I still don't know how to provide a reference to models which are not in the ~/.gazeo/models directory.
Originally posted by Subodh Malgonde with karma: 31 on 2018-08-12
Comment by Raskkii on 2018-08-13:
What is the output of "echo $GAZEBO_MODEL_PATH"?
Comment by Subodh Malgonde on 2018-08-23:
This environment variable is not set by ROS. So the output is blank. After I set it in .bashrc, I get the output. However it did not fix my problem.
Comment by Raskkii on 2018-08-23:
Try changing the command set in .bashrc slightly: export GAZEBO_MODEL_PATH=${GAZEBO_MODEL_PATH}:/home/my_user/my_catkin_ws/src/ The difference here is that this adds your custom path to the existing model path (which should be ~/.gazebo/models) and doesn't overwrite it, allowing both paths to be used.
