Gazebo Answers logo
The robot tool is a prismatic gripper with four rods that slip into matching holes on the object to be grasped. Using this gripper to move the object works fine for motion perpendicular to the rod axes. In the video, for example, the rods are parallel to the world x-axis so motion in the z-y plane is fine; the robot lifts the object then translates in the negative y-direction okay. I think the problem is that the friction force is not being computed well because when the robot translates in the x-direction the object seems to stay put until it reaches the end of the rod and then it goes berserk. (If you look closely in the second video it can be seen that the gripper starts to move to the right and the object stays still. I guess the object crosses the camera in that video so we get to see the holes and rods inside the object.)
object and gripper
object and gripper closeup
There is a second reason I think the friction calculation is to blame: a different pick-and-place simulation I made this year had problems lifting objects via friction. See Question 1, Question 2, and Question 3.
update: This video where I replaced the gripper with a rigid forklift-type attachment lends weight, I think, to the idea that the problem is due to physics (friction?) and not the ROS controller or something.
forks instead of gripper
I've tried using all four physics engines and modifying physics tags in the world file, as well as collision surface tags in both the object sdf and the gripper urdf. It's apparent that changing these parameters has some effect (though mu1 and mu2 don't make any difference) but the problem persists. The files are pasted below.
It also seems to me that this could be a problem to do with Gazebo 9, which is what I moved to because the previous project had a mobile base that could not move due to this bug with Gazebo 7 and ros_control. Since this simulation does not have a mobile base I will try reverting to Gazebo 7 to see if that fixes the gripping problem.
update: The behavior is identical with Gazebo 7. I've seen the same thing on two computers running Gazebo 9 and now one computer running Gazebo 7.
An additional tidbit: if the mass of the object is too high (though still less than 1) it will fall during the upward motion. So that's fun :-/
World file:
<sdf version='1.5'>
  <world name='default'>
    <!-- A global light source -->
    <include>
      <uri>model://sun</uri>
    </include>
    <!-- A ground plane -->
    <include>
      <uri>model://ground_plane</uri>
    </include>
    <!-- Set physics parameters to hopefully improve contact behavior -->
    <!-- Default max_step_size is 0.001 -->
    <!-- Product of r_t_u_r and m_s_s gives target realTimeFactor, I think.  Default is 1000. -->
    <!-- Default iters is 50 -->
    <physics type="ode">
      <max_step_size>0.0005</max_step_size>
      <real_time_update_rate>2000</real_time_update_rate>
      <ode>
    <solver>
      <iters>100</iters>
    </solver>
      </ode>
    </physics>
  </world>
</sdf>
Object sdf:
<sdf version='1.6'>
  <model name='object'>
    <link name='object'>
      <pose frame=''>0 0 0 0 0 0</pose>
      <inertial>
        <pose frame=''>0 0.00594 0.31407 0 0 0</pose>
        <mass>0.01</mass>
        <inertia>
          <ixx>0.01</ixx>
          <ixy>0</ixy>
          <ixz>0</ixz>
          <iyy>0.01</iyy>
          <iyz>0</iyz>
          <izz>0.01</izz>
        </inertia>
      </inertial>
      <collision name=object_collision'>
    <surface>
      <contact>
        <ode>
          <max_vel>0</max_vel>
          <min_depth>0.0001</min_depth>
          <kp>1e8</kp>
          <kd>1e0</kd>-->
        </ode>
      </contact>
      <friction>
        <ode>
          <mu>1000000.0</mu>
          <mu2>1000000.0</mu2>
        </ode>
      </friction>
    </surface>
        <geometry>
          <mesh>
            <scale>0.0254 0.0254 0.0254</scale>
            <uri>model://object/meshes/object.stl</uri>
          </mesh>
        </geometry>
      </collision>
      <visual name='object_visual'>
        <geometry>
          <mesh>
          </mesh>
        </geometry>
      </visual>
    </link>
  </model>
</sdf>
Gripper urdf:
<?xml version="1.0" ?>
<!-- |    This document was autogenerated by xacro from gripper_placer.urdf.xacro      | -->
<!-- |    EDITING THIS FILE BY HAND IS NOT RECOMMENDED                                 | -->
<robot name="gripper_placer" xmlns:xacro="http://ros.org/wiki/xacro">
  <!-- Default is 0.01 -->
  <!-- 0.0393701 -->
  <!-- Phantom link for center of gripper -->
  <link name="gripper_center">
    <inertial>
      <mass value="0.01"/>
      <inertia ixx="0.0001" ixy="0.0" ixz="0.0" iyy="0.0001" iyz="0.0" izz="0.0001"/>
    </inertial>
  </link>
  <!-- One side of gripper -->
  <link name="side_p">
    <visual>
      <origin rpy="0 0 0" xyz="0 0 0.11485"/>
      <geometry>
        <mesh filename="package://hydra/models/gripper_placer/meshes/gripper_pad_v2.stl" scale="0.0254 0.0254 0.0254"/>
      </geometry>
    </visual>
    <collision>
      <geometry>
      </geometry>
    </collision>
    <inertial>
      <mass value="0.001"/>
      <inertia ixx="0.01" ixy="0.0" ixz="0.0" iyy="0.02" iyz="0.0" izz="0.02"/>
    </inertial>
  </link>
  <!-- Second side of gripper -->
  <link name="side_d">
    <visual>
      <origin rpy="0 0 3.14159265359" xyz="0 0 0.11485"/>
      <!--origin xyz="0 0.04185 0" rpy="0 0 ${pi}" /-->
      <geometry>
      </geometry>
    </visual>
    <collision>
      <geometry>
      </geometry>
    </collision>
    <inertial>
    </inertial>
  </link>
  <!-- Prismatic joint -->
  <joint name="gripper_joint_p" type="prismatic">
    <origin rpy="0 0 0" xyz="0 0 0"/>
    <axis xyz="0 1 0"/>
    <parent link="gripper_center"/>
    <child link="side_p"/>
    <limit effort="5000" lower="-100" upper="100" velocity="0.5"/>
  </joint>
  <joint name="gripper_joint_d" type="prismatic">
    <axis xyz="0 1 0"/>
    <child link="side_d"/>
  </joint>
  <transmission name="gripper_joint_transmission_p">
    <type>transmission_interface/SimpleTransmission</type>
    <joint name="gripper_joint_p">
      <hardwareInterface>hardware_interface/PositionJointInterface</hardwareInterface>
    </joint>
    <actuator name="gripper_joint_motor_p">
      <mechanicalReduction>1</mechanicalReduction>
    </actuator>
  </transmission>
  <transmission name="gripper_joint_transmission_d">
    <joint name="gripper_joint_d">
    </joint>
    <actuator name="gripper_joint_motor_d">
    </actuator>
  </transmission>
  <!-- Gazebo tag for hopefully changing physics engine properties to work -->
  <gazebo>
    <maxVel>0</maxVel>
    <minDepth>0.001</minDepth>
  </gazebo>
</robot>
Originally posted by raequin on Gazebo Answers with karma: 165 on 2018-08-09
Comment by Raskkii on 2018-08-10:
Does the result vary at all depending on the speed of movement in the x-axis? What if you move the crane very slowly?
Comment by josephcoombe on 2018-08-10:
It would be interesting to advance the simulation by single time steps right before and as it transitions along the x-axis. That might reveal what objects are interpenetrating and what's causing the large impulse.
Comment by raequin on 2018-08-14:
For some unknown reason I did not receive email notifications about your comments. Thanks for responding! @Raskkii, as far as I can discern, there is no way to set the translational velocity for a MoveIt! cartesian path. @josephcoombe, here is a video of stepping through the sim. https://www.youtube.com/watch?v=19kJmpXPQ9M Please read its description on YouTube. What's vexing is that manipulating objects is common in Gazebo and I can't think of anything unusual about this system.
Gazebo Answers logo
The cause behind this unrealistic interaction (that is, this lack of friction) is the use of PositionJointInterface for the UR10 joints. Here's a decent explanation of the phenomenon:
... using 'set position' or 'set velocity' in gazebo forces the physics simulation to try and accomplish this, which results in strange behavior. It's actually preferable, according to the Gazebo team members I'm working with, to always use 'set force' in Gazebo because that allows a more normal interaction when the commanded force of an arm joint puts the arm in contact with the environment.
Following an example, I made local changes to the universal_robot package to use EffortJointInterface instead. Some gain values from ARIAC provide decent performance. Thanks to everyone who contributed suggestions!
Originally posted by raequin with karma: 165 on 2018-09-17
