Here is the disassembled stepper motor that I'm working with:
Contains the photo of the motor, and the label that's on the bottom of the motor.
I need to identify this stepper motor that was retrieved from scrap for a project. Budget constraints force us to use the scrap motor. I tried to drive this using a L298 H Bridge, but I couldn't find the right bit sequences to get this running smoothly. I also tried to search for a specifications sheet in the internet with the label, unsuccessfully.
I'm using either an RPi or Arduino board to run this.
I just need a pin diagram and the specifications of the motor, if you guys have seen this type before.
