You need to set a gazebo tag in your urdf file.
For example, if I have a link safety_lidar to represent my sensor, I will add the following tag :
<gazebo reference="velodyne_${lidarName}">
<sensor type="ray" name="velodyne_sensor_${lidarName}">
<pose>0.0 0.0 0.0 0.0 0 0</pose>
<visualize>false</visualize>
<update_rate>10</update_rate>
<ray>
<scan>
<horizontal>
<samples>${sample_number}</samples>
<min_angle>${min_angle}</min_angle>
<max_angle>${max_angle}</max_angle>
</horizontal>
<vertical>
<samples>16</samples>
<min_angle>-0.26</min_angle>
<max_angle>0.26</max_angle>
</vertical>
</scan>
<range>
<min>0.30</min>
<max>100.0</max>
</range>
</ray>
<plugin name="gazebo_ros_velodyne_controller_${lidarName}" filename="libblock_laser_plugin.so">
<topicName>/velodyne_${lidarName}</topicName>
<frameName>velodyne_${lidarName}</frameName>
<alwaysOn>true</alwaysOn>
<gaussianNoise>0.00</gaussianNoise>
<updateRate>10.0</updateRate>
<hokuyoMinIntensity>1</hokuyoMinIntensity>
</plugin>
</sensor>
</gazebo>
I am using xacro parameters (${}) to adapt my sensor.
Originally posted by Brosseau.F with karma: 284 on 2018-02-15
Comment by RoboticRos on 2018-02-16:
Thanks.....
@Brosseau ... It is not publishing any topics. ${lidarName} --> This can be anything (name) i want it to be be ... right??
Comment by Brosseau.F on 2018-02-16:
Yes it can be the name you want. You have to replace all the parameters with the value that you want.
This part of urdf is inside a xacro macro, that's why there is some ${parameters}.
Comment by Subodh Malgonde on 2018-08-11:
The plugin needs to be updated to libgazebo_ros_laser.so
, then this works.
