Gazebo Answers logo
Hello everyone.
I am trying to display my model robot in gazebo and get this warning:
Deprecated syntax, please prepend 'hardware_interface/' to 'PositionJointInterface' within the tag in joint 'joint_base'.
I know it's not important but I want to solve it.
This is my code in the xacro file of the transmission block:
<xacro:macro name="transmission_block" params="joint_name">
  <transmission name="tran1">
    <type>transmission_interface/SimpleTransmission</type>
    <joint name="${joint_name}">
      <hardwareInterface>PositionJointInterface</hardwareInterface>
    </joint>
    <actuator name="motor1">
      <mechanicalReduction>1</mechanicalReduction>
    </actuator>
  </transmission>
</xacro:macro>
Originally posted by Daniel Tobon on Gazebo Answers with karma: 23 on 2017-05-21
Comment by lejan on 2021-05-06:
Hi, I have the same warning, but when I append "hardware_interfase/" I receive this:
No matching hardware interface found for 'hardware_interfase/EffortJointInterface' while loading interfaces for pitch_joint
Gazebo Answers logo
As you said, it is just a warning and doesn't break anything. To stop the message, simply follow the warning message to get:
<hardwareInterface>hardware_interface/PositionJointInterface</hardwareInterface>
Originally posted by hamzamerzic with karma: 40 on 2017-05-21
Comment by Daniel Tobon on 2017-05-23:
thaaank you!!
Comment by Mav14 on 2017-11-08:
I have a related issue. My transmission is set up as
And this is the error I get Could not find resource 'waist' in 'hardware_interface::EffortJointInterface'.. I can't figure out what's causing that despite looking everywhere.
