I looked through the Messages API and tried to use WorldModify messages like this:
- send a WorldModify message with
remove
set totrue
andworld_name
set todefault
to close the current world (also tried to reference the world with "worlds/empty.world") - send a WorldModify message with
create
set totrue
andworld_name
set to, for example,worlds/pioneer2dx.world
in order to open a new world
The result is that if I have the client open it crashes, otherwise (if gazebo is running headless) nothing changes. I have also tried to first pause the world then send the WorldModify messages and then do a reset with a WorldReset message but again nothing happened. I check with gz topic -e /gazebo/world/modify
that gazebo receives the messages, so I guess I'm not using them properly.
Is it possible to open/close worlds via messages? If it is, how do you do that?
Originally posted by gshopov on Gazebo Answers with karma: 13 on 2016-03-23
