Gazebo Answers logo
Hi everybody, In my plugin I want to set the angle of a revolute joint according with a particular dynamic. To do this I used the function
void gazebo::physics::Joint::SetAngle ( unsigned int  _index, math::Angle  _angle)
This function in declared as GAZEBO_DEPRECATED(version). When I try to compile the code, I have this return :
warning: 'void gazebo::physics::Joint::SetAngle(unsigned int, gazebo::math::Angle)' is deprecated (declared at /usr/include/gazebo-5.2/gazebo/physics/joint.hh:396 [-Wdeprecated-declaretions].
I'm not able to understand why I can't use this function. Is there a method that enables the user to use this type of function?
I tried to add this piece of code :
 #if defined(__GNUC__)
 #define GAZEBO_DEPRECATED(version) __attribute__((deprecated))
 #define GAZEBO_FORCEINLINE __attribute__((always_inline))
 #elif defined(_WIN32)
 #define GAZEBO_FORCEINLINE __forceinline
 #else
 #define GAZEBO_DEPRECATED(version) ()
 #endif
But appears an error like:
may not appear in macro parameter list
Otherwise, is there other functions that can make the same thing of SetAngle?
Thank you, bye!
Originally posted by gabri89 on Gazebo Answers with karma: 19 on 2016-02-29
Gazebo Answers logo
I don't know how to use a deprecated function (maybe it depends on the gazebo version you use).
The new function should be SetPosition .
https://osrf-distributions.s3.amazonaws.com/gazebo/api/dev/classgazebo_1_1physics_1_1Joint.html
Originally posted by Brosseau.F with karma: 284 on 2016-02-29
Comment by gabri89 on 2016-02-29:
Thank you, the error disappears! I hope that the joint will behave as I want.
