Gazebo Answers logo
I followed the tutorial(animated box) here: Animated box. After I 'make' it in the build folder, I got the error in the file independent_listener.cc
 error: ‘setupClient’ is not a member of ‘gazebo’
What's the matter?
PS. I use gazebo 1.9 with ROS hydro on Ubuntu 12.04 LTS. The content of independent_listener.cc:
#include <gazebo/transport/transport.hh>
#include <gazebo/msgs/msgs.hh>
#include <gazebo/gazebo.hh>
#include <iostream>
// Function is called every time a message is received.
void posesStampedCallback(ConstPosesStampedPtr &posesStamped)
  std::cout << posesStamped->DebugString();
  ::google::protobuf::int32 sec = posesStamped->time().sec();
  ::google::protobuf::int32 nsec = posesStamped->time().nsec();
  std::cout << "Read time: sec: " << sec << " nsec: " << nsec << std::endl;
  for (int i =0; i < posesStamped->pose_size(); ++i)
    const ::gazebo::msgs::Pose &pose = posesStamped->pose(i);
    std::string name = pose.name();
    if (name == std::string("box"))
      const ::gazebo::msgs::Vector3d &position = pose.position();
      double x = position.x();
      double y = position.y();
      double z = position.z();
      std::cout << "Read position: x: " << x
          << " y: " << y << " z: " << z << std::endl;
int main(int _argc, char **_argv)
  // Load gazebo
  gazebo::setupClient(_argc, _argv);
  // Create our node for communication
  gazebo::transport::NodePtr node(new gazebo::transport::Node());
  node->Init();
  // Listen to Gazebo pose info topic
  gazebo::transport::SubscriberPtr sub =
  node->Subscribe("~/pose/info", posesStampedCallback);
  // Busy wait loop...replace with your own code as needed.
  while (true)
    gazebo::common::Time::MSleep(10);
  // Make sure to shut everything down.
  gazebo::shutdown();
Originally posted by winston on Gazebo Answers with karma: 449 on 2015-03-02
Gazebo Answers logo
Hi,
your gazebo is probably too old, as you can see the tutorial applies for versions 4+
Cheers, Andrei
Originally posted by AndreiHaidu with karma: 2108 on 2015-03-03
Comment by winston on 2015-03-03:
Yes, you are right. I just found out the answer but forgot to post it. 'setupClient' is not defined in the old version of Gazebo. Thanks.
Comment by Lucas Walter on 2017-07-06:
In gazebo 7+ it is supposed to be gazebo::client::setup(argc, argv), include gazebo_client.hh instead of gazebo.hh and need to include gazebo_config.hh initially to get GAZEBO_MAJOR_VERSION.
