Hi,
I've written a ModelPlugin which calls physics::Joint::SetForce(int, double) on a revolute joint using the ODE physics engine. According to the documentation Gazebo API doc this should only work for SimBody and DART engine (I'm using gazebo 4.1). However, it works as expected.
My question is: can I safely use this with ODE, i.e. it's only an error in the documentation, or do I have to expect this behaviour will break in some update?
Originally posted by Moritz on Gazebo Answers with karma: 15 on 2015-01-23
