Gazebo Answers logo
I am using Hydro on Gazebo 1.9. I have made a utility vehicle model that is based off of the DRC Vehicle (using the DRC Vehicle/Vehicle ROS plugins). I am currently trying to match the dynamics of the model as closely as possible to the actual, real vehicle that I have. I get the Gazebo vehicle to move by applying a command rotational velocity to the back wheels through gazebo_msgs::LinkState /gazebo/set_link_state. The thing that is strange to me is that whether I give a small or large command velocity, it always takes approximately 2 seconds for the settling time to reach the command velocity. This means that if I give a small command velocity, the acceleration is small and if I give a large command velocity, the acceleration is large. I would think that the vehicle would take more time to reach a higher command velocity - is there any way I can make this more realistic? I've tried different types of vehicles and this behavior is consistent. I've also thought about giving command velocity as steps but since it always take 2 seconds to get to the command velocity, I wouldn't be able to get to a desired total time of like 3 seconds, only multiples of 2.
Thanks in advance for any advice you can provide!
EDIT: my drive node
  ros::init(argc, argv, "toro_gazebo_drive_pub");
  ros::NodeHandle n;
  ros::Publisher publ = n.advertise<gazebo_msgs::LinkState>("/gazebo/set_link_state", 1000);
  ros::Publisher publ2 = n.advertise<gazebo_msgs::LinkState>("/gazebo/set_link_state", 1000);
  ros::Rate loop_rate(20);
  while(ros::ok())
  gazebo_msgs::LinkState msg; //gazebo_msgs::ApplyJointEffortTEST
  gazebo_msgs::LinkState msg2; //for second back wheel
  double mpers = 0.5; // m/s of vehicle
  msg.link_name = "drc_vehicle_xp900::toro::rear_left_wheel"; //  husky::back_left_wheel
  msg.pose.position.x = 0.0; // don't edit position.x though angular.x
  msg.pose.position.y = 0.0;
  msg.pose.position.z = 0.0;
  msg.pose.orientation.x = 0.0;
  msg.pose.orientation.y = 0.0;
  msg.pose.orientation.z = 0.0;
  msg.pose.orientation.w = 1.0;
  msg.twist.linear.x = 0.0;
  msg.twist.linear.y = 0.0;
  msg.twist.linear.z = 0.0;
  msg.twist.angular.x = 0.0;
  msg.twist.angular.y = 2.3875*mpers*10; // can modify this to move (+ = forward, - = backward), 2.3875 is for .1m/s
  msg.twist.angular.z = 0.0;
  msg.reference_frame = "drc_vehicle_xp900::toro::rear_left_wheel"; //  husky::back_left_wheel
  msg2.link_name = "drc_vehicle_xp900::toro::rear_right_wheel"; //  husky::back_right_wheel
  msg2.pose.position.x = 0.0; // don't edit position.x though angular.x
  msg2.pose.position.y = 0.0;
  msg2.pose.position.z = 0.0;
  msg2.pose.orientation.x = 0.0;
  msg2.pose.orientation.y = 0.0;
  msg2.pose.orientation.z = 0.0;
  msg2.pose.orientation.w = 1.0;
  msg2.twist.linear.x = 0.0;
  msg2.twist.linear.y = 0.0;
  msg2.twist.linear.z = 0.0;
  msg2.twist.angular.x = 0.0;
  msg2.twist.angular.y = 2.3875*mpers*10; // can modify this to move (+ = forward, - = backward)
  msg2.twist.angular.z = 0.0;
  msg2.reference_frame = "drc_vehicle_xp900::toro::rear_right_wheel"; //  husky::back_right_wheel
  publ.publish(msg);
  publ2.publish(msg2);
  ROS_INFO_STREAM("Sending back-wheel drive command:" << " wheels spinning at " << msg.twist.angular.y << " rad/s" << std::endl);//" rotation(z, steer) = " << msg.twist.angular.z << std::endl);
  ros::spinOnce();
  loop_rate.sleep();
  return 0;
Originally posted by nbanyk on Gazebo Answers with karma: 104 on 2014-12-15
Comment by nbanyk on 2014-12-18:
Is there any rhyme or reason as to how questions get answered in this forum? Like for my question, did I 1) write a confusing question? 2) ask a question that no one knows the answer to? 3) ask a dumb question? 4) just not wait long enough for a response?
The reason I ask this is because I've tried a number of different ways and spent a lot of time trying to adjust my model/world and if I can't get this to work then I need to drop the Gazebo side of my project.
Comment by hsu on 2014-12-18:
are you setting joint velocity or applying effort at joint to achieve a velocity?
I'm setting a link velocity through the topic, gazebo_msgs::LinkState, to the two rear wheel links. I was trying to use gazebo_ros in a way that only used topic/msgs without any services/srvs. I've edited my post so that I show the node that I use to drive the vehicle.
setting joint [link] velocity bypasses dynamics, so resulting behavior will not obey newton's second law. To make use of physics and dynamics properly, I recommend creating a PID controller to set joint effort commands and use joint velocity as feedback. One approach I might take is by writing a model plugin (http://gazebosim.org/tutorials?tut=plugins_model&cat=write_plugin) to do this.
Ohhh, ok, I didn't know that that bypasses dynamics. For the model plugin method, do you have an example of giving a joint effort w/ or w/o PID control? I know that tutorial link applies a linear velocity and not an effort.
Well, set velocity with ODE uses a linear motor, and the effect is that the solver finds a sufficient force to achieve velocity requested, so not exactly real-world like.
Ok, so I think I'm a bit confused. Should I be setting velocity using 'this->model->SetLinearVel' to get to my command velocity in a plugin, or is there a different set command for setting effort that I should use instead? Is there some reference/wiki where I can learn about the code to use for plugins (I found the bitbucket page for gazebo plugin examples but those don't have a lot of motion other than model_push)? And then, how can I get ROS to communicate with the Gazebo plugin to give...
...a command velocity or effort? I know that there is the 'Using Gazebo plugins with ROS' wiki page but that only deals with sensor plugins and skid steer/differential drive. (I am using SDF for my model and not URDF).
To guarantee that an effort is applied on every simulation step, ModelPlugin approach is preferred. Use Joint::SetForce call (https://bitbucket.org/osrf/gazebo/src/6592c20d6b458911b17c2797364fec6b8365d199/gazebo/physics/Joint.hh?at=gazebo_1.9#cl-267) to apply joint efforts. I don't have a simple example handy at the moment, maybe someone else watching this thread does? Another alternative is to to use ros_control (http://wiki.gazebosim.org/wiki/Tutorials/1.9/ROS_Control_with_Gazebo)
Comment by nbanyk on 2014-12-19:
Thanks, I will try Joint::SetForce. As for the ros_control, can transmission elements be used in an SDF too? I thought that it could only be done on a URDF.
Comment by nbanyk on 2015-02-04:
I have a plugin with Joint::SetForce working when I start Gazebo by typing Gazebo but I instead get a "process has died" exit code 139 error when launching through ROS (roslaunch). For some reason the SetForce is the source of the issue. Roslaunch works if I just have 'this->model->GetJoint("rear_left_wheel_joint");' but if I have 'this->model->GetJoint("rear_left_wheel_joint")->SetForce(1,5.0); I get the error. Any ideas as to why?
I realized what the issue was - I had everything correct except I had a model within a model so my line should have read: this->model->GetJoint("toro::rearleftwheeljoint")->SetForce(1,5.0); where 'toro::' comes before my joint name. Marking this thread as solved.
Gazebo Answers logo
Follow the comments to see the progression that Hsu helped me get through to the solution.
Originally posted by nbanyk with karma: 104 on 2015-02-04
