I am building a 6 wheeled rover, one set of 3 wheels will work together and other set of 3 wheels will run together, so current in each side may vary from 3A-15A(blocked rotor) and 6V i want to make a H-bridge(for controlling direction and speed(i ll use PWM) so i will require two such H-bridges. what is the copper track thickness i should use in proteus for making the design or else shall i go for manual soldering replacing tracks with wires. Can anybody suggest a design which is relatively easy to design with some protection circuit in it (for MCU pins isolation) or suggest any suitable motor controllers from TI or any company which can be apt to my problem
$\begingroup$ Welcome to Robotics Ruthvik Vaila, but you may well find that you get a better answer for a pure electrics question like this over on electronics. If the answers you get here don't satisfy you, please flag this question and it can be migrated. Please don't just ask the question again there though, migration helps keep sites with slightly overlapping areas linked together. Thanks, $\endgroup$– Mark Booth ♦Apr 7, 2014 at 23:11
$\begingroup$ There is some good advice on track widths in answers to the questions How to carry high current on PCB and Sizing a trace on a PCB to carry 2.5 amps $\endgroup$– Mark Booth ♦Apr 8, 2014 at 0:20
1 Answer
If you can purchase a motor driver board, Pololu has some that probably fit your specs. This board uses the VNH2SP30 from ST. The Pololu board is rated for operating voltages from 5.5V to 16V and a continuous current of 14A (peak of 30A). Continuous current and peak current of course depend on how well cooled the driver chip is.
You could also create your own design around a driver chip like the VNH2SP30. The datasheet has a standard application circuit that you may base your design off of. When designing your board, the copper thickness, usually specified in ounces of copper, is the same for the whole board and is typically 1 oz for external traces. Once you know the thickness, you can calculate the width of the trace based on the current through it. Wider traces have lower resistance per unit length and thus heat less and can handle higher current.
