I have a Raspberry Pi (Model B) attached to a Roomba. I'm using this part to bring the unregulated 17V+ power of the Roomba down the 5V/1A of the Pi. The problem is that the Pi will randomly reboot and cause peripherals (such as the bluetooth adapter) to freak out and not work. We can sometimes drive it around for a little while before it reboots, other times it happens almost immediately.
9
  • $\begingroup$ 1. What does the Roomba spec on the 17V supply? 2. Did you put a scope on both sides of this (the input and output of your regulator)? $\endgroup$
    – Guy Sirton
    Commented Mar 27, 2014 at 23:52
  • $\begingroup$ 3. did you follow the application notes here tracopower.com/products/tsr1.pdf ? $\endgroup$
    – Guy Sirton
    Commented Mar 27, 2014 at 23:56
  • $\begingroup$ I went looking for a source online, and it turns out the battery is 14.4 volts, at lease for a comparable replacement battery. I'm an idiot and after reading these comments I realized I forgot the capacitors. What is L1? $\endgroup$
    – Ian Hyzy
    Commented Mar 28, 2014 at 17:54
  • $\begingroup$ You should rewrite that comment as an answer to the question so that it can receive upvotes. $\endgroup$
    – Ian
    Commented Mar 28, 2014 at 21:10
  • $\begingroup$ I'm not trying step down more then 32V and I don't need to meet "EN 55022 class A", do I still need those things? I'm getting 5V and 1A out to the Pi. $\endgroup$
    – Ian Hyzy
    Commented Mar 29, 2014 at 2:29
The Raspberry Pi B, and in particular the Raspberry Pi B2 are fairly sensitive to having enough current to meet their peek power needs. For most of my apps, I have been using a 1.5A supply, and that has been more than sufficient for the Raspberry Pi B+, however when I started trying to use the Raspberry Pi B2 I needed a peak of 3A to be able to not have it "brown out" and reboot.
I would recommend upping your available power, and see if it makes a difference.
