Gazebo Answers logo
I'm pretty new to Gazebo, so I apologize. I'm confused about Gazebo plugins. I have used the skid steer plugin and the differential drive plugins that were in a Gazebo tutorial and they both worked fine in my robot models. So I know how to use plugins, at least a little.
Now I'm starting to add sensors to my robot models and I can't figure out how to use the hector_gazebo_plugins GazeboRosSonar plugin. http://wiki.ros.org/hector_gazebo_plugins
Is this something that is already built into Gazebo or ROS or is this something that I need to download and build on my machine? If the latter, then where are the download and install instructions? The above URL appears to just be API documentation.
I'm using ROS Hydro and Gazebo 1.9.
Originally posted by Kurt Leucht on Gazebo Answers with karma: 50 on 2014-07-03
Gazebo Answers logo
You may as well install the compiled one with:
$ sudo apt-get install ros-hydro-hector-gazebo-plugins
What are you using for your robot model? .urdf or .sdf? Assuming .urdf here you can find an usage example.
Hope this helps
Originally posted by Francisco with karma: 143 on 2014-07-05
Comment by Kurt Leucht on 2014-07-05:
Thanks. I'm new enough that I sometimes forget to try the ros-[version]-[package name] naming convention.
Comment by Kurt Leucht on 2014-07-07:
It works! Thanks!
Comment by BlackViper on 2018-08-09:
I know this is a two year old question, but I am in the same boat. How did you make it work? I tried replacing the {name} with my link name and setting the visualization to true but there is no laser visualization in gazebo.
Gazebo Answers logo
You need to download these plugins. You can do this from this page :
https://github.com/tu-darmstadt-ros-pkg/hector_gazebo
You have to download/clone this into your catkin workspace and run catkin_make. then you can use the hector_gazebo plugins.
Originally posted by Bharath with karma: 21 on 2014-07-04
