Gazebo Answers logo
Hi everyone,
I am using Gazebo 1.9 with ROS groovy. As I am trying the RRBot example(Link here), I kept getting the following error messages when launching gazebo:
Error [Plugin.hh:127] Failed to load plugin libgazebo_ros_camera.so: libCameraPlugin.so: cannot open shared object file: No such file or directory
Error [Plugin.hh:127] Failed to load plugin libgazebo_ros_gpu_laser.so: libGpuRayPlugin.so: cannot open shared object file: No such file or directory
I am using gazebo_ ros_ pkg within catkin workspace, and the ".so" files are actually located in /home/mark/catkin_ws/devel/lib.
Any comments or suggestions would be appreciated!
Originally posted by Mark_GU on Gazebo Answers with karma: 11 on 2013-09-30
Comment by vncntmh on 2013-10-01:
Hello,
I'm working in RRbot but I have problems with the catkin_make in this Tutorial
http://gazebosim.org/wiki/Tutorials/1.9/Using_A_URDF_In_Gazebo
the problem is when to used:
cd ~/catkin_ws/src/
git clone https://github.com/ros-simulation/gazebo_ros_demos.git
cd ..
catkin_make
Comment by vncntmh on 2013-10-01:\
Get this error:
File "/opt/ros/groovy/bin/catkinmake", line 14, in <module> from catkin.terminalcolor import     disableANSIcolors, fmt
ImportError:
Comment by Mark_GU on 2013-10-01:
@vncntmh Not quite familiar with your problem, it looks like something went wrong with your catkin workspace. Does "catkin_make" work before your included the package "gazebo_ ros_ demos"?
@Mark_GU, the problem were because I had used ros/fuerte and it change to ros/groovy
A lot of thanks!!
Gazebo Answers logo
Hi,
what is in your GAZEBO_PLUGIN_PATH variable (type echo $GAZEBO_PLUGIN_PATH in a terminal)
if it not contains /home/mark/catkin_ws/devel you should append it (type GAZEBO_PLUGIN_PATH=$GAZEBO_PLUGIN_PATH:/home/mark/catkin_ws/devel)
I haven't found this in the tutorial but I think it must be there somewhere ;)
you can find it in the manual Manual plugins
hope this solves your problem
Originally posted by evilBiber with karma: 881 on 2013-10-01
Thank you. I tried the method your suggested. Somehow my GAZEBO_ PLUGIN_ PATH shows nothing by default. So now even if I added "/home/mark/catkin_ws/devel" to it, I still get the error. Thus I was wondering if any other path is needed
Gazebo Answers logo
Hello,
Check this post:
http://answers.gazebosim.org/question/4535/error-pluginhh127/
Goodbye!!
Can you please show me all the paths included in your GAZEBO_ PLUGIN_ PATH? Because my GAZEBO_ PLUGIN_ PATH defaults to nothing. Even when I added the path that includes the .so file, it is still showing the error. Thanks
Okay,
My path is libmyplugin.so and this's In ~/gazebo/my_plugin/build
Before to get this path I used:
cmake ..;make  //in the folder /build
I used:
cd ~/gazebo/my_plugin/build  //here is libmyplugin.so
export GAZEBO_PLUGIN_PATH=`pwd`:$GAZEBO_PLUGIN_PATH  //with this instruction I load libmyplugin.so and it's prepared it for load the simulation
gazebo
In my case I insert the robot from Gazebo
hope this solves your problem, GoodBye!!
