Gazebo Answers logo
Hi,
is there a simple solution for getting the coordinates on which the rays of a sensor hit a target? At the moment I calculate the points myself by using the sensor pose, the start and end angles and the samples, but I think there has to be an easier way to do that...
image description
Originally posted by Chris on Gazebo Answers with karma: 67 on 2013-07-29
Gazebo Answers logo
That's the easiest way. Gazebo mimics the output from laser range finders, which is typically angle and range readings.
Originally posted by nkoenig with karma: 7676 on 2013-07-30
Comment by Chris on 2013-07-31:
Ok, thank you!
