Gazebo Answers logo
I've just installed the latest drcsim. From what I've read, a way to use python scripts is included in the ros package it comes with, rospy.
However, when I try to use rospy, the terminal does not recognize the command, when I searched for it with which rospy, nothing came up.
For some reason, rospy is not be included in the drcsim package, how do I go about installing it?
Originally posted by David Jeang on Gazebo Answers with karma: 34 on 2013-07-18
Comment by evilBiber on 2013-07-19:
Hi, have you sourced the needed files? you have to source the drcsim setup.sh source /usr/share/drcsim/setup.sh in every terminal if this does not source the ros files you might have to source them manually too. source /opt/ros/fuerte/setup.bash
if you are using this frequently you should at the source command to your .bashrc files
Comment by David Jeang on 2013-07-20:
Files were already sourced in the .bashrc files, this is not the issue.
Gazebo Answers logo
Issue has been resolved. Apparently, latest modifications has changed rospy to rospython, so I can use that to launch my script.
Originally posted by David Jeang with karma: 34 on 2013-07-29
