Gazebo Answers logo
hello all
I have successfully implement the move_base package onto the gazebo. My goal is to move the robot to a specify position in x,y,z coordinate without too much worrying about avoiding the ostacles. Any ideas in which package I could use?
Originally posted by gazer on Gazebo Answers with karma: 5 on 2013-06-13
Comment by Mrit91 on 2013-07-02:
You could either give a command through the terminal using rosservice call /gazebo setmodelstate pose, or you could write a code using this service and run it.
Gazebo Answers logo
What do you mean by "successfully implement the move_base package onto the gazebo"?
If you are using ROS, you can create a map of the environment for navigation purposes.
Originally posted by nkoenig with karma: 7676 on 2013-07-03
