Gazebo Answers logo
Hello, I am a newbee.. I have recently installed ubuntu precise and Ros groovy (full desktop) by following the instructions on the ros wiki. Next I am trying to install the Gazebo. I have done the following commands: sudo sh -c 'echo "deb http://packages.osrfoundation.org/gazebo/ubuntu quantal main" > /etc/apt/sources.list.d/gazebo-latest.list'
wget http://packages.osrfoundation.org/gazebo.key -O - | sudo apt-key add - wget http://packages.ros.org/ros.key -O - | sudo apt-key add -
sudo apt-get update sudo apt-get install gazebo
. /usr/share/gazebo/setup.sh echo "source /usr/share/gazebo/setup.sh" >> ~/.bashrc source ~/.bashrc gazebo
when i run the last command, I get the following error: Gazebo multi-robot simulator, version 1.8.1 Copyright (C) 2013 Open Source Robotics Foundation. Released under the Apache 2 License. http://gazebosim.org
Msg Waiting for master Msg Connected to gazebo master @ http://127.0.0.1:11345 Msg Publicized address: 192.168.0.2 X Error of failed request: BadAlloc (insufficient resources for operation) Major opcode of failed request: 154 (GLX) Minor opcode of failed request: 3 (X_GLXCreateContext) Serial number of failed request: 16 Current serial number in output stream: 17
Please help, as this is an urgent work and i am time bound. regards,
Originally posted by SAMJT on Gazebo Answers with karma: 16 on 2013-05-25
Gazebo Answers logo
Thank you for the reply... ur clue has really helped out. On google search, I found the following forum answer and it is working for me now http://askubuntu.com/questions/124292/what-is-the-correct-way-to-install-ati-catalyst-video-drivers-fglrx/126513#126513
cheers :-)
Originally posted by SAMJT with karma: 16 on 2013-05-25
Comment by AndreiHaidu on 2013-05-25:
I am glad you made it work, you should mark your answer as correct, in case if others run into the same problem, they know how to fix it. And maybe add to the title something regarding ATI graphics cards, so it will make more sense. Cheers :)
