Gazebo Answers logo
cannot get atlas.launch to work. I installed 12.04 ubuntu 64 bit. installed ROS and gazebo as per the wiki page. When I ran the drc simulator atlas.launch.
I get the following. nny ideas..
Gazebo multi-robot simulator, version 1.4.0 Copyright (C) 2013 Open Source Robotics Foundation. Released under the Apache 2 License. http://gazebosim.org
Msg Waiting for master.Msg Waiting for master Msg Connected to gazebo master @ http://127.0.0.1:11345 Msg Publicized address: 10.0.0.10 Xlib: extension "GLX" missing on display ":0". Error [RenderEngine.cc:623] Unable to create glx visual Warning [RenderEngine.cc:87] Unable to create X window. Rendering will be disabled
Msg Connected to gazebo master @ http://127.0.0.1:11345 Msg Publicized address: 10.0.0.10 Xlib: extension "GLX" missing on display ":0". Error [RenderEngine.cc:623] Unable to create glx visual Warning [RenderEngine.cc:87] Unable to create X window. Rendering will be disabled Warning [InsertModelWidget.cc:242] The manifest.xml for a Gazebo model is deprecated. Please rename manifest.xml to model.config for model "/usr/share/drcsim-2.1/gazebo_models/environments/stepping_block" gazebo: /usr/include/boost/smart_ptr/shared_ptr.hpp:418: T* boost::shared_ptr::operator->() const [with T = gazebo::rendering::UserCamera]: Assertion `px != 0' failed.
Originally posted by dezulm on Gazebo Answers with karma: 16 on 2013-03-09
Gazebo Answers logo
Thanks! I have a lenovo thinkpad w520 which comes with nvidia quadro card but I did not install any additional drivers. It is currently using the default ubuntu drivers. I did not see nvidia drivers for quadro board on the list of nvidia drivers anyway.
Originally posted by dezulm with karma: 16 on 2013-03-11
Comment by AndreiHaidu on 2013-03-11:
check if your GPU is properly installed, here is a way: install mesa utils $ sudo apt-get install mesa-utils and then run $ glxgears
