Gazebo Answers logo
when I run gazebo, the errors appear:
1\Error [ModelDatabase.cc:290] Unable to parse manifest.xml for model[http://gazebosim.org/models/double_pendulum_with_base] 2\ Error [ModelDatabase.cc:290] Unable to parse manifest.xml for model[http://gazebosim.org/models/kitchen_dining] 3\ gazebo: /usr/include/boost/smart_ptr/shared_ptr.hpp:418: T* boost::shared_ptr::operator->() const [with T = gazebo::common::NumericAnimation]: Assertion `px != 0' failed.
why appear these? how to solve it?
Originally posted by lugd1229 on Gazebo Answers with karma: 75 on 2013-02-24
Comment by bit-pirate on 2013-02-26:
I just filled a ticket for this issue: https://bitbucket.org/osrf/gazebo/issue/537/manifest-error-in-gazebosimorg-database
Gazebo Answers logo
manifest.xml files are being deprecated, and replaced with model.config. We are doing this to remove naming conflicts with ROS. New models in the database will not have manifest.xml files. So the solution to your problem is to upgrade Gazebo.
Originally posted by nkoenig with karma: 7676 on 2013-03-07
Comment by bit-pirate on 2013-03-08:
Am I assuming right that the update to 1.5 for ROS Groovy users will solve this issue?
