Hello I got an issue with a humanoid robot modeled in sdf format. The model itself is fine. However, my problem is the model slips, slides, and can't stay in place as soon as i move a joint (via plugin of window).
The model plug in is not the problem in this case.
I tried inserting the tags, tags but they don'e work. I suspect I need a separate world plugin but i am not sure about this since the model already has a plugin.
You anyone please advise?
Thank you
Originally posted by nordegren on Gazebo Answers with karma: 1 on 2013-01-30
Comment by nkoenig on 2013-01-30:
Please post your SDF files, and tell us what version of Gazebo you're using.
Comment by nordegren on 2013-02-03:
i am using Gazebo I am not comfortable posting the whole sdf file. Can i post an sdf file that has only the lower body, that is with links (visual + collision) and joints?
Comment by nordegren on 2013-02-06:
thank you hsu i will saw the mu values and they are way higher than what i have, in fact these values are crazy high. i will post some of the code for the links and joints once i figure how to properly use this website.
Comment by nordegren on 2013-02-07:
here is a sample of a link
Comment by nordegren on 2013-02-07:\
.030 -.090 .010 0 0 0 1.5 1.00.00.01.00.01.0 .300 .120 .020 model:// --> 0.3Comment by nordegren on 2013-02-07:\ .030 -.090 .010 0 0 0 1.5 1.00.00.01.00.01.0 .300 .120 .020 model:// --> 0.3Comment by nordegren on 2013-02-07:\ .030 -.090 .010 0 0 0 1.5 1.00.00.01.00.01.0 .300 .120 .020 model:// --> 0.3Comment by nkoenig on 2013-03-07:It will be hard to debug your problem without a complete SDF file. We can take this offline so that you don't have to post a complete SDF. Please contact me using [email protected]
