I need to read the location of my device within a 1m radius sphere, with accuracy of 5-10cm.
The device is handheld and wireless, and currently communicates using a Bluetooth v4 chip. I could add an RF transmitter on the moving part and a few stationary receivers at the base.
What components should I look into? What would be the cheapest way to triangulate it?
TOA method is almost impossible to work at such short lengths with radio signals (as they travel at the speed of 3*10^8 m/s which means you need a very high sampling rate to detect that time difference). You should consider using some ultrasonic sound sources and microphones and use them for such a task. If you wish to know the location of the device in 3 dimensions, you need to place one sound emitter onto the moving device and 4 microphones at the center of the sphere. The more apart the microphones are, the better precision you'll have.
