Gazebo Answers logo
We've noticed that the IMU and force-torque sensors are extremely noisy (well beyond expectation for real sensors). I imagine this is likely a result of the normal imperfections of simulating physics in discrete time steps.
Are there parameters that we can adjust to significantly improve the fidelity of the simulation (perhaps at cost of a much slower simulation)?
Related, but not quite the same question:
Originally posted by asomerville on Gazebo Answers with karma: 283 on 2013-01-14
Comment by isura on 2013-01-14:
An issue was created for the linked post.https://bitbucket.org/osrf/drcsim/issue/85/imu-too-noisy
Gazebo Answers logo
It's an error inherent in the existing LCP solver given performance requirements. You can run simulation slower to get better results. For example, figure below from running:
roslaunch atlas_utils atlas.launch
rxplot /atlas/imu/linear_acceleration/z
image description
If you increase physics->solver->iterations from default of 40 to 80, the oscillation magnitude decreases (the spike is just an artifact of parameter update):
image description
Setting iterations to 500 reduces oscillation magnitudes even further:
image description
Alternatively, you can low pass filter the data. As an extremely crude example, exponential filter where
accel(new) = (1 - e) * accel(new) + e * accel(old)
where e = 0.9 leads to:
image description
Originally posted by hsu with karma: 1873 on 2013-02-26
Comment by isura on 2013-03-07:
I also noticed that the noise increased as the joint PID gains of Atlas was increased. This is a problem since the low gain joint controllers (specifically the ones in drcsim whole body yaml) cannot follow trajectories very well.
Specifically, is this a numerical problem that will be solved at some point or should we plan on using low gains, filter and/or increase the iterations?
Comment by asomerville on 2013-03-18:
Not sure if it's correct to ask here, but along the lines of this question: Will time step be configurable? Do you know if such adjustments to time-step or iterations will be allowed for the DRC?
Comment by nkoenig on 2013-03-18:
Contestants in the VRC will not be allowed to control properties of the physics engine.
