Gazebo Answers logo
If the file path is relative, which is the base directory and how can we specify it?
Thanks
Originally posted by logicalguy on Gazebo Answers with karma: 73 on 2012-11-09
Comment by Erik Stoltenborg on 2012-11-09:
I think its the directory of the world file, are you also getting directory not found error?
Comment by logicalguy on 2012-11-12:
Hi, I am getting an error that says "Image filename is empty"
Comment by nkoenig on 2012-11-14:
I believe this is an error that you can ignore, and has been removed in the default branch. Are you experiencing any related problems?
Comment by logicalguy on 2012-11-16:
when I specify a png heightmap, it doesn't load the heightmap, instead a large 2d black rectangle where the heightmap should be. The Pioneer robot is next to this space on the ground. I have attached a screenshot of gazebo, my heightmap mage, and the world file at http://inky.ws/g/2cz
oh, and I am using gazebo-1.2.5
Gazebo Answers logo
Base paths for relative URIs are specified in environment variables. For example GAZEBO_RESOURCE_PATH.
Originally posted by nkoenig with karma: 7676 on 2013-01-11
