I have a Raspberry Pi hooked up to a Roomba 560's serial port. While going over the spec, I noticed movement controls weren't as simple as I expected. I can't send bytes larger than 255, but, according to the spec, to go straight I have to send 8000. How does this work?
EDIT: My solution was the following three functions:
import serial
import time
def start():
    #Open serial connection
    global ser
    ser = serial.Serial('/dev/ttyUSB0', 115200)
    # this is the defualt Roomba baud rate
    # Start SCI - puts into safe mode
    ser.write(chr(128))
    # Enable the safe mode
    ser.write(chr(131))
    # this is required or the command may fail
    time.sleep(1)
# This makes the serial command fit the big-endian notation
def make4(num):
    num = num[2:]
    z2a = 4-len(num)
    for q in range(z2a):
        num = '0' + num
    return '\\x'+num
def move(vel, rad):
    # Init move command
    ser.write(chr(137))
    # velocity
    vhex = hex(vel)
    vhex = make4(vhex)
    #radius
    vrad = hex(rad)
    vrad = make4(vrad)
    # send to roomba
    ser.write(vhex)
    ser.write(vrad)
The spec says hex 8000 as in hexadecimal (which I usually write in C/Python notation as 0x8000). Each byte is exactly two hexadecimal digits. So you can break 0x8000 into 0x80 and 0x00 and send them separately, which correspond to decimal numbers 128 and 0.
You also have to know which to send first (referred as little-endian vs big-endian). The spec says [radius high byte] [radius low byte], so high byte comes first (big-endian).
Therefore send the sequence [128, 0] in order to transmit hex 8000.
  • $\begingroup$ Thanks! I was able to make some nice functions using Python's hex() function so I can put in easily-understandable numbers. $\endgroup$
    – Ian Hyzy
    Mar 1, 2014 at 23:06
