Gazebo Answers logo
Hello,
can anyone tell me how to draw lines via messages or from a plugin? I already tried DynamicLines and Scene->DrawLine from inside a world plugin but without results. It either crashed the server or nothing happened at all.
Thanks for the help and best regards Bastian
Originally posted by Karandaras on Gazebo Answers with karma: 76 on 2012-10-11
Gazebo Answers logo
Thanks for the answer. I already added a simple way of drawing to the Scene class. It is probably not the best way, but it works for me and allows me to continue my work.
Here is the code I used for that.
Added needed stuff to the Scene header
gazebo/rendering/Scene.hh
/// \brief Subscribe to draw for line drawing
private: transport::SubscriberPtr drawingSub;
/// \brief Drawing callback
/// \param[in] _msg The message data.
private: void OnDrawing(ConstDrawingPtr &_msg);
/// \brief Process a drawing message
private: bool ProcessDrawingMsg(ConstDrawingPtr &_msg);
/// \def DrawingMsgs_L
/// \brief List of drawing messages.
typedef std::list<boost::shared_ptr<msgs::Drawing const> > DrawingMsgs_L;
/// \brief List of drawing message to process.
private: DrawingMsgs_L drawingMsgs;
New functions for the drawing
gazebo/rendering/Scene.cc
void Scene::OnDrawing(ConstDrawingPtr &_msg)
  boost::mutex::scoped_lock lock(*this->receiveMutex);
  this->drawingMsgs.push_back(_msg);
bool Scene::ProcessDrawingMsg(ConstDrawingPtr &_msg)
  Ogre::SceneNode *sceneNode = NULL;
  Ogre::ManualObject *obj = NULL;
  bool attached = false;
  if (this->manager->hasManualObject(_msg->name()))
    sceneNode = this->manager->getSceneNode(_msg->name());
    obj = this->manager->getManualObject(_msg->name());
    attached = true;
  else
    sceneNode = this->manager->getRootSceneNode()->createChildSceneNode(_msg->name());
    obj = this->manager->createManualObject(_msg->name());
  sceneNode->setVisible(_msg->visible());
  obj->setVisible(_msg->has_visible());
  obj->estimateVertexCount(_msg->point_size());
  obj->clear();
  std::string material = "Gazebo/Red";
  if(_msg->has_material()) {
    material = _msg->material();
  if(!_msg->has_mode())
    obj->begin(material, Ogre::RenderOperation::OT_LINE_LIST);
  else if(_msg->mode() == msgs::Drawing::POINT_LIST)
    obj->begin(material, Ogre::RenderOperation::OT_POINT_LIST);
  else if(_msg->mode() == msgs::Drawing::LINE_LIST)
  else if(_msg->mode() == msgs::Drawing::LINE_STRIP)
    obj->begin(material, Ogre::RenderOperation::OT_LINE_STRIP);
  else if(_msg->mode() == msgs::Drawing::TRIANGLE_LIST)
    obj->begin(material, Ogre::RenderOperation::OT_TRIANGLE_LIST);
  else if(_msg->mode() == msgs::Drawing::TRIANGLE_STRIP)
    obj->begin(material, Ogre::RenderOperation::OT_TRIANGLE_STRIP);
  else if(_msg->mode() == msgs::Drawing::TRIANGLE_FAN)
    obj->begin(material, Ogre::RenderOperation::OT_TRIANGLE_FAN);
  int p = _msg->point_size();
  for(int i=0; i<p; i++) {
    obj->position(_msg->point(i).position().x(), _msg->point(i).position().y(), _msg->point(i).position().z());
    if(_msg->point(i).has_color())
      obj->colour(Conversions::Convert(msgs::Convert(_msg->point(i).color())));
  obj->end();
  if (!attached)
    sceneNode->attachObject(obj);
  if(_msg->has_pose()) {
    sceneNode->setPosition(Conversions::Convert(msgs::Convert(_msg->pose().position())));
    sceneNode->setOrientation(Conversions::Convert(msgs::Convert(_msg->pose().orientation())));
  return true;
Changes adding the new function to be processed during prerender
void Scene::PreRender()
  static SensorMsgs_L::iterator sensorIter;
  static LinkMsgs_L::iterator linkIter;
  static DrawingMsgs_L::iterator drawingIter;
  // Process the link messages
  linkIter = this->linkMsgs.begin();
  while (linkIter != this->linkMsgs.end())
    if (this->ProcessLinkMsg(*linkIter))
      this->linkMsgs.erase(linkIter++);
    else
      ++linkIter;
  // Process the drawing messages
  drawingIter = this->drawingMsgs.begin();
  while (drawingIter != this->drawingMsgs.end())
    if (this->ProcessDrawingMsg(*drawingIter))
      this->drawingMsgs.erase(drawingIter++);
    else
      ++drawingIter;
Registering the new subscriber
Scene::Scene(const std::string &_name, bool _enableVisualizations)
  this->sceneSub = this->node->Subscribe("~/scene", &Scene::OnScene, this);
  this->drawingSub = this->node->Subscribe("~/draw", &Scene::OnDrawing, this);
Message definition
gazebo/msgs/drawing.proto
package gazebo.msgs;
/// \ingroup gazebo_msgs
/// \interface Drawing
/// \brief Message that is used to draw inside gazebo
/// \verbatim
import "vector3d.proto";
import "pose.proto";
import "color.proto";
message Drawing
  enum Mode
    POINT_LIST     = 1;
    LINE_LIST      = 2;
    LINE_STRIP     = 3;
    TRIANGLE_LIST  = 4;
    TRIANGLE_STRIP = 5;
    TRIANGLE_FAN   = 6;
  message Point
    required Vector3d position  = 1;
    optional Color color        = 2;
  required string name          = 1;
  required bool visible         = 2;
  optional Pose pose            = 3;
  optional string material      = 4;
  optional Mode mode            = 5;
  repeated Point point          = 6;
/// \endverbatim
It is probably not the best way to solve my problem, but it works for me.
Bastian
Here are the files/patches, hope everything works, since I am not familiar with diff
Drawing.proto
Patch for CMakeLists.txt
Patch for Scene.cc
Patch for Scene.hh
Originally posted by Karandaras with karma: 76 on 2012-10-21
Comment by Karandaras on 2013-01-05:
I would be glad to hear if my code got used. Keep up the good work with the simulator.
Comment by nkoenig on 2013-01-09:
I will start integrating you code shortly. For future reference, it's better to submit changes through a pull request on our bitbucket site: http://bitbucket.org/osrf/gazebo.
Comment by nkoenig on 2013-01-11:
Ticketed here: https://bitbucket.org/osrf/gazebo/issue/382/render-via-message
