Gazebo Answers logo
Is there some documentation about how to build Gazebo for ROS after trying to apply some patches? I do need bumper sensors, which are still broken in 1.6.16 on Gazebo for ROS Fuerte.
The known patch was promised for 1.6.17, but this has not been released (as of 02/Oct/2012)...
A normal rosbuild either does nothing, or first downloads and then unpacks the "magic" tarballs with ROS-compatible Gazebo checkouts, which in turn overwrites any patches applied to the source tree...
Is the following correct?
  1. install ros-fuerte-simulator-gazebo package
  2. remove any existing ROS_NOBUILD
  3. rosmake --pre-clean
    (which downloads the magic tarball, unpacks, compiles everything)
  4. cd to the actual gazebo source tree
  5. edit some source files, apply patches, etc.
  6. make
  7. make install
  8. cd to simulator_gazebo; touch ROS_NOBUILD
I am (trying to) use Gazebo on ROS Fuerte with the Shadow hand model. The latest available release version is 1.6.12, with
Originally posted by Norman on Gazebo Answers with karma: 1 on 2012-10-03
Gazebo Answers logo
Hi,
I'd recommend the following steps:
  1. leave the debian installs (things inside /opt/ros/fuerte/* untouched) and work off of an overlay by following the steps below. If you have already changed files inside of /opt/ros/fuerte/*, you might want to consider reinstalling affected packages by
sudo apt-get install --reinstall ros-fuerte-simulator-gazebo
  1. create a workspace directory and cd into it
     mkdir ~/workspace
     cd ~/workspace
  1. checkout simulator_gazebo stack.
    svn co https://code.ros.org/svn/ros-pkg/stacks/simulator_gazebo/branches/simulator_gazebo-1.6 simulator_gazebo
  1. let ros know you want to use this stack instead of the one inside /opt/ros/fuerte/... and refresh rospack
    export ROS_PACKAGE_PATH=~/workspace:$ROS_PACKAGE_PATH
    rospack profile
  1. build simulator_gazebo. Note that gazebo is pulled in from mercurial repo and built (see Makefile.gazebo.hg).
    rosmake simulator_gazebo
  1. to make changes to gazebo, go inside the mercurial checkout inside simulator_gazebo/gazebo/build/gazebo-hg/.
Note that above is compiled against a ''fuerte''-branch inside of gazebo repository, it's a snapshot back at revision gazebo-1.0.2. I've been testing it with gazebo-1.2.0 release candidate, if you want to test that branch out, get the sdf_1.2 branch
svn co https://code.ros.org/svn/ros-pkg/stacks/simulator_gazebo/branches/sdf_1.2 simulator_gazebo
But this is not yet completely stable. And to run pr2 simulation, you might also want to checkout pr2_common along with it due to changes in SDF:
svn co https://code.ros.org/svn/wg-ros-pkg/stacks/pr2_common/branches/sdf_1.2 pr2_common
as well as pr2_simulator
svn co https://code.ros.org/svn/wg-ros-pkg/stacks/pr2_simulator/trunk pr2_simulator
into your workspace.
Originally posted by hsu with karma: 1873 on 2012-10-05
