I had installed ROS Noetic on Windows 11 but eventually decided to dual-boot my laptop with Ubuntu, so I went to uninstall ROS-Noetic from Windows, but am not able to do so because of the following error:
Windows ROS-Noetic Error
It is still taking up 5.70 GB of storage space. If anyone knows a solution, please help.
I have tried running rmdir /s /q c:\opt in the terminal, but I get
The system cannot find the file specified.
From other stack overflow posts, it's not uncommon to run into issues using the rmdir command for basic operations like this one.
You could try:
  • using the absolute path to work around a windows bug (source)
  • using the bash shell, or WSL, to delete the file instead of powershell, etc. (source)
  • compressing the folder so it's an archive and then deleting the archive (source)
Looks like this is a windows issue not a ROS issue, so I'd be searching through information on that.
