For testing purposes, I am running Gazebo sim (i.e. 'new Gazebo') with logging enabled:
gz sim -v 4 world.sdf
This works, but there's a lot of irrelevant debug output (e.g. gui, simulationrunner, SystemManager, etc).
Is there a way to filter the log output?
In other words: is there an equivalent command for Gazebo sim, to following ROS 2 command:
ros2 run <package> <executable> --ros-args --log-level DEBUG --log-level rcl:=INFO
which configures loglevel 'debug' for all loggers, except for the rcl logger which gets loglevel 'info' (and hence does not output (many) messages).
I believe there's only a global setting (-v 4). One thing that might be useful is that you can run the server and the gui in two separate terminals with gz sim -s -v4 world.sdf and gz sim -g respectively with different verbosity flags.
  • $\begingroup$ Not the answer I was hoping for, but the suggestion to run in separate terminals is relevant. In the end I resorted to using regular std::cout instead of gzdbg since the white cout output contrasts with the other (colored) messages. Another possibility (which I did not try) could be to use bash color codes in the log messages. $\endgroup$
    – JRTG
    Aug 5, 2023 at 18:32
