I have big problem. I have to solve inverse kinematics for a manipulator with 6-DOF using jacobian method. From what I know to do that I need to have matrix of transformation and Denavit–Hartenberg parameters, which both I have. But I am not a mathematician, and descriptions I find on the web are not even a bit understandable to me. So I would love if you could give me an example of how to solve my problem.
The Denavit-Hartenberg parameters are: $$ \begin{matrix} \alpha & l & \lambda & \theta\\ 90 & 150 & 0 & var(-69) \\ 0 & 610 & 0 & var(85) \\ 90 & 110 & 0 & var(-52) \\ -90 & 0 & 610 & var(62) \\ 90 & 0 & 113 & var(-60) \\ 0 & 0 & 78 & var(-108) \\ \end{matrix} $$
The values in theta are values to get the following matrix of transformation, and values I want to get with this jacobian method. And those values are in degrees.
Matrix of transformation: $$ \begin{matrix} 0.7225 & 0.0533 & 0.6893 & 199.1777\\ -0.2557 & -0.9057 & 0.3381 & -500.4789\\ 0.6423 & -0.4206 & -0.6408 & 51.6795\\ 0 & 0 & 0 & 1 \\ \end{matrix} $$
I would be most greatful, if someone could walk me through how to solve it in simple language.
