I've been building some code to do reinforcement learning on robots in a ros-gazebo environment, using ros2 humble and (ignition) gazebo fortress. My code is running fine on my machine, but when I build a docker image to run it on the university computing cluster I'm receiving the following error:
[Err] [EntityComponentManager.cc:1026] Failed to create component of type [9436740692853731264] for entity [58]. Type has not been properly registered.
[Err] [EntityComponentManager.cc:1026] Failed to create component of type [9436740692853731264] for entity [59]. Type has not been properly registered.
[Err] [EntityComponentManager.cc:1026] Failed to create component of type [9436740692853731264] for entity [60]. Type has not been properly registered.
Segmentation fault (core dumped)
My docker file looks like this:
FROM ros:humble-ros-base-jammy
RUN apt-get update
RUN apt-get install -y python3-pip wget
RUN wget https://packages.osrfoundation.org/gazebo.gpg -O /usr/share/keyrings/pkgs-osrf-archive-keyring.gpg
RUN echo "deb [arch=$(dpkg --print-architecture) signed-by=/usr/share/keyrings/pkgs-osrf-archive-keyring.gpg] http://packages.osrfoundation.org/gazebo/ubuntu-stable $(lsb_release -cs) main" | sudo tee /etc/apt/sources.list.d/gazebo-stable.list > /dev/null
RUN apt-get update
RUN apt-get install -y ignition-fortress
RUN apt-get install -y ros-humble-ros-gz
RUN pip install tensorflow
Could there be some dependency missing from my image?
One relevant thing may be that I'm running programatically gazebo using the following code:
#include "simulation.hh"
#include <stdexcept>
#include <ignition/gazebo/ServerConfig.hh>
#include <ignition/gazebo/Server.hh>
using namespace ignition::gazebo;
void Simulation::start() {
    ServerConfig config;
    config.SetSdfFile(_sdfPath);
    _server = new Server(config);
void Simulation::step() {
    if(_server)
        _server->RunOnce(false);
    else
        throw std::runtime_error("Simulation not started: call start first!");
Starting gazebo in the docker container using the console seems to work fine.
Ok I've got it working now. Doesn't really answer why it wasn't working, but it was taking the version of gazebo fortress installed by ros-gz rather than the one I installed directly. Building it from source and making sure my code is using that version fixed my issue.
