I know that inverse kinematics ($p \rightarrow q$, p: desired pose of the end-effector, q: joint angles) is not a function because there might be multiple joint angle vectors q that result in the same pose p.
By inverse dynamics control I mean the mapping $(q, \dot{q}, \ddot{q}) \rightarrow u$ (u: required torques. I am not very experienced with these kind of problems. Is the mapping a function, i.e. for each triple $(q, \dot{q}, \ddot{q})$ there is a unique solution u? My intuition says it is. But I am not sure. If there is not, would it always be possible to obtain a solution by averaging two or more solutions?
  • $\begingroup$ Is this inverse dynamics? i don't think so. mapping joint positions, velocities, and accelerations to the required joint torques is low level control. $\endgroup$
    – Ben
    Commented Feb 24, 2014 at 1:48
  • $\begingroup$ At least in this paper it seems like it is: robot-learning.de/pmwiki/uploads/Publications/… $\endgroup$
    – alfa
    Commented Feb 24, 2014 at 7:15
I think you are confusing 2 issues. Inverse dynamics is the process of mapping end effector position, velocity, and acceleration to joint torques. as described in this book, page 298: http://books.google.com/books?id=jPCAFmE-logC&lpg=PR2&pg=PA298#v=onepage&q=inverse%20dynamics&f=false
But the paper you posted is simply modeling and calibrating their robot's non-geometric parameters.
So i think there can be multiple solutions to the inverse dynamics problem as i define above. because when only given the end effector parameters, the arm can potentially be in different configurations to realize this. a simple example is a 2 link planar arm where the elbow can be on either side. as seen in figure 2.31, page 93: http://books.google.com/books?id=jPCAFmE-logC&lpg=PR2&pg=PA93#v=onepage&q=two-link%20planar%20arm&f=false
but i still think the problem as you describe, mapping joint position, velocity, and acceleration to joint torques is a low-level control problem and probably has a unique solution. however, when factoring in nonlinearities like friction can probably make the answer non-unique. for example, imagine a joint with lots of friction. a range of joint torques will be sufficient to hold the joint at a given angle.
  • $\begingroup$ OK, thanks for clarification. I was not able to come up with such a simple example that obviously results in multiple solutions. However, for me it is important that the average of two or more solutions is a solution, too. But that would be guaranteed in your example. Thanks! $\endgroup$
    – alfa
    Commented Feb 24, 2014 at 15:51
  • $\begingroup$ By the way, I edited the question a little bit. Maybe it sounds a little bit more correct now. ;) $\endgroup$
    – alfa
    Commented Feb 24, 2014 at 15:54
  • $\begingroup$ Ben, if you read carefully the Sciavicco's book you'll find out how the inverse dynamics is not concerned about what you said. In general, indeed, inverse dynamics problem is regarded with the solution of the dynamic equation of the manipulator $M(q)\ddot{q}+h(q,\dot{q})=u_c$ with the aim of seeking the torque $u_c$ that drives the system to make $(\ddot{q},\dot{q},q)$ follow some reference $(\ddot{q}_r,\dot{q}_r,q_r)$. In case you have non-null end-effector force $h_e$ you have to consider it in the equation. $\endgroup$ Commented Dec 26, 2014 at 19:26
