Until now, I just used examples of the ros documentation e.g. for the publisher
self.publisher_ = self.create_publisher(String, 'topic', 10)
and it all worked well. It looks like 10 could mean, in that case, the number of kept history items - but I'm not sure !?
In the rclpy documentation, there is no hint about what 10 could mean in that case.
I even looked at the source code but I don't get it.
Can anyone clarify where to really look, to understand what the proper values are for the third parameter?
For C++
I might be wrong, but (for C++ not Python) from rclcpp::Node Class Reference
std::shared_ptr< PublisherT >     create_publisher (const std::string &topic_name, size_t qos_history_depth, std::shared_ptr< Alloc > allocator=nullptr)
and
std::shared_ptr< PublisherT >     create_publisher (const std::string &topic_name, const rmw_qos_profile_t &qos_profile=rmw_qos_profile_default, std::shared_ptr< Alloc > allocator=nullptr)
In both cases, the last parameter is
Then from create_publisher(), it says that the third parameter is
[in] allocator Optional custom allocator.
Notes:
For Python
Actually, above, I was wrong.
From the link to the rclpy documentation that you posted, click on the API link in the left hand side bar.
Then click on the Publisher link (under "Topics"):
Read the warning (ignore the typo):
Warning:
Users should not create a publisher with this constuctor, instead they should call Node.create_publisher().
Click the link to Node.create_publisher()
Looking at
create_publisher(msg_type, topic, qos_profile, *, callback_group=None, event_callbacks=None, qos_overriding_options=None)
The third parameter is
  • qos_profile (Union[QoSProfile, int]) – A QoSProfile or a history depth to apply to the publisher. In the case that a history depth is provided, the QoS history is set to KEEP_LAST, the QoS history depth is set to the value of the parameter, and all other QoS settings are set to their default values.
