I have two bag files with significant overlap and multiple loop closure opportunities. However, these bag files were recorded at different times. I want to use these bag files to reconstruct a scene and chain the reconstructions together. Currently, I am using fastlio with scancontext.
However, when I run the second bag file in the same fastlio session, the reconstruction breaks, possibly due to imu initialization issues. If I keep the scancontext session and restart the fastlio session, the reconstruction gets placed at 0,0,0, and scancontext cannot find a proper match.
Can anyone suggest a workflow for chaining the reconstructions together using multi-session data and bag files with significant overlap? How can I avoid these initialization issues in fastlio and maintain the proper placement of the reconstruction using scancontext?
I would also like to ask if there are alternative solutions for using Livox LiDARs (Mid-360) and offline SLAM to chain reconstructions together with multi-session bag file data.
After struggling with this for a while, the best repo I have found for offline reconstruction/pose graph optimization and merging multisession data is interactive slam. https://github.com/SMRT-AIST/interactive_slam
Have you tried the graph optimization approach?
  1. Cut the fastlio local map into segments
  2. Generate a pose graph from the segments
  3. Repeat 1,2 for the other dataset
  4. Run a place recognition algorithm like BoW3D or scancontext to find the correspondence between the segments
  5. Find the 6 dof transformations between the matchings
  6. Add them to the graph
  7. Run the optimization
