I am trying to find the forward kinematics of this manipulator in the picture using DH notation. All of the joints are rotational.
Manipulator picture
I managed to get to the third joint. The parameter table is below.
Joint Theta d a alpha
1 q_1 d_1 0 pi/2
2 q_2 0 d_2 0
3 q_3 0 d_3
5
6
I am not sure what the alpha for joint 3 should be. Any help would be appreciated.
  • $\begingroup$ Welcome to Robotics This looks like a homework question, and on stack exchange, questions asking for homework help must include a summary of the work you've done so far to solve/understand the problem, and a description of the difficulty you are having solving/understanding it. Please edit your question to add this information and take a look at How to Ask and tour for more information on how stack exchange works. For advice on how to write a good question, see the Robotics question checklist. $\endgroup$
    – Tully
    Apr 20 at 15:32
I would suggest watching Robotics 1 U1 (Kinematics) S5 (HTM) P2 (HTM by Denavit Hartenberg), to learn how to find DH-parameter table.
Alpha values can be found out by the rotation of the first frame to the second frame's x-axis to match the z-axis with second frame. Therefore, here the alpha value for joint-3 would be pi/2 when we rotate frame 3 around frame 4's x-axis to match the z-axis.
