I have a Raspberry Pi with this FTDI cable and a Roomba 560. The Roomba has an SCI port to allow for control of the roomba via serial. I installed the PySerial library on the pi and send valid commands to Roomba, but the roomba doesn't respond. I have the TXD of the cable attached to the TXD of the roomba, the RXD on the cable wired to the RXD on the roomba, and a ground on the cable wired to the ground on the roomba (everything in it's respective port). I do not have power going from the cable to the roomba or vice-versa.
What I can't figure out is why the commands aren't working. There's no error message upon running the python code. This is the information sheet for the Roomba's SCI port.
Code:
import serial
ser = serial.Serial('/dev/ttyUSB0')
# this is the defualt Roomba baud rate
ser.baudrate = 57600
# Start SCI - puts into safe mode
ser.write(chr(128))
# Enable full mode
ser.write(chr(131))
# Spot clean
ser.write(chr(134))
print 'Done'
