I recently made a release of image_transport_plugins in ROS noetic, but the noetic debian binary builds have started failing afterwards.
Looking at the logs, the issue seems to be apt coming from an invocation of apt-get install ... catkin on the BuildFarm, but I can't quite figure out why catkin is getting installed rather than ros-noetic-catkin.
All logs have the following problem:
01:20:43 Invoking 'apt-get install -q -y -o Debug::pkgProblemResolver=yes apt-src catkin debhelper image-transport-tools libcv-bridge-dev libdynamic-reconfigure-config-init-mutex-dev libgmock-dev libgtest-dev libimage-transport-dev libogg-dev librosbag-dev libstd-msgs-dev libtheora-dev pluginlib-dev python3-cv-bridge python3-dynamic-reconfigure python3-rosbag python3-std-msgs ros-message-generation ros-std-msgs'
01:20:43 Reading package lists...
01:20:44 Building dependency tree...
01:20:44 Reading state information...
01:20:44 Starting pkgProblemResolver with broken count: 5
01:20:44 Starting 2 pkgProblemResolver with broken count: 5
Does anyone know, or have come across similar issues?
Buildfarm failures Logs:
Nbin_dbv8_dBv8__theora_image_transport__debian_buster_arm64__binary Nbin_dbv8_dBv8__compressed_image_transport__debian_buster_arm64__binary Nbin_dbv8_dBv8__compressed_depth_image_transport__debian_buster_arm64__binary Nbin_db_dB64__theora_image_transport__debian_buster_amd64__binary Nbin_db_dB64__compressed_image_transport__debian_buster_amd64__binary Nbin_db_dB64__compressed_depth_image_transport__debian_buster_amd64__binary
Looking at the ros/rosdistro PR which included this release, the bloom version used was 0.10.7 which is quite old compared to the current 0.11.2 version from the time of the release PR.
I have not been able to determine what is causing this with older bloom versions on current distributions but using the current version of bloom to re-run bloom-release ... resolves it.
