Looking to derive these equations. I don't intuitively understand what it means to take a cos of two independent angles added together. Nor do I understand why all of these are equal to 0. It is hard to visualize when all the angles seem independent.enter image description here
I think perhaps you can proceed as follows:
  1. First consider the each segment as a vector, $\bar{r}_1$, $\bar{r}_2$, etc.
  2. The vectors each add as you place the tip of each to the tail of the following: $\bar{r}$ = $\bar{r}_1$ + $\bar{r}_2$ + $\bar{r}_3$ + $\bar{r}_4$
  3. But you know that when you do this you just end up back at the origin - i.e.
$$\bar{r} = \bar{r}_1 + \bar{r}_2 + \bar{r}_3 + \bar{r}_4 = 0$$
  1. This means that the $x$ and $y$ components must each add up to zero as well, since $\bar{r}$ = $\hat{x}x$ + $\hat{y}y$ $= 0$:
$$x = x_1 + x_2 + x_3 + x_4 = 0$$
$$y = y_1 + y_2 + y_3 + y_4 = 0$$
This is where the first two equations come from, with, e.g.:
$$x_1 = L_1\cos\theta_1$$ $$x_2 = L_2\cos(\theta_1+\theta_2)$$ $$\ldots$$
The last equation simply expresses the fact that you will end up back at the beginning as you rotate through each angle:
$$\theta_1 + \theta_2 + \theta_3 + \theta_4 = 2\pi$$
If some of the derivations are still a mystery, I recommend this paper from the MIT AI Lab. It is quite old but very clear.
