I want to simulate a RR robot in gazebo and I want to place the first link over a box. This box shouldn't be a part of the simulation, and is there only for visual effect.
How can I make a specific link/object static?
I created a fixed joint with a link named "world". Also, I tried adding a static tag.
However, it still included in the physics calculations, resulting in a weird behaviour. It spins on its own and it tilts, like this:
Relevant parts of the urdf:
<link name="world"/>
<joint name="world_joint" type="fixed">
<parent link="world"/>
<child link="base_link"/>
<origin rpy="0 0 0" xyz="0 0 ${base_height}"/>
</joint>
<link name="base_link">
<visual>
</visual>
<collision>
</collision>
<inertial>
<mass value="100" />
<inertia ixx="0.1" ixy="0.0" ixz="0.0"
iyy="0.1" iyz="0.0"
izz="0.1" />
<origin rpy="0 0 0" xyz="0 0 ${-base_height/2}"/>
</inertial>
</link>
<gazebo reference="base_link" >
<material> Gazebo/Blue </material>
<static>true</static>
</gazebo>
I made the inertia of the base_link greater
<inertia ixx="100" ixy="0.0" ixz="0.0" iyy="100" iyz="0.0" izz="100" />
and now the base doesn't tilt and the link doesn't rotate on its own. However, as I specified it as a static link, I anticipated that it shouldn't have that behaviour no matter its inertia.
Edit After some more searching, i found out that you cannot specify a link as static (sdf documentation). However, i still expect that the fixed joint with the world frame would keep the box in place.
I also changed some parameters of the physics engine, namely erp and cfm (you can find them here), but the weird behaviour continued.
and now the base doesn't tilt and the link doesn't rotate on its own. However, as i specified it as a static link, i anticipated that it shouldn't have that behaviour no matter its inertia. $\endgroup$
