I'd like to modify this example of recording a bag file from a ROS node written in Python to be able to effectively start and stop recording using a service call. My thought is I could create self.writer = rosbag2_py.SequentialWriter()
in my service callback, and add some logic in the callbacks for the topic subscriptions to ensure that it will only try to write the data if self.writer
exists and is ready to be written to.
I think what I describe should work for starting recording, my question is how will I handle safely stopping the recording, such that I can subsequently start recording a new bag file again with a subsequent service call. Since there is an open
function on SequentialWriter
, I was expecting to see a close
or flush
function, but I don't see such functionality in the exposed Python API. My guess then is that maybe this isn't working like how I normally think of files being "open" in Python.
So, what I would like to know: what is the correct way to "stop" recording when using the Python API? Is it sufficient to simply call self.writer.open()
with different StorageOptions
that assign a new uri
to save to? If I do that, am I somehow leaving "open" resources dangling?
UPDATE (1/2):
It seems there is in fact a close
, but only in the C++ API and it's not offered yet in the Python bindings. There is an issue on GitHub that gives some awareness to this.
UPDATE (2/2):
I wrote what I described in C++, and me calling the close
just caused my program to crash without any error. I ended up finding the package system_data_recorder that implements the functionality I needed of being able to programmatically start/stop bag recording. They use node lifecycles to manage start/pause/resume/stop recording and have the added benefit that they can copy incremental chunks of the bags to a copy location so that you can incrementally save your data to a backup. Very nice!
