The following code creates a bridge between rclpy.spin
and an application built around Python's asyncio
. The guard condition is used to interrupt rmw_wait
and hence return early from spin_once
(to handle the case where nothing else is happening). I am using Python 3.6, but I think the same principles apply to later versions of Python with the addition of some nicer APIs being available.
import threading
import asyncio
import rclpy
from rclpy.node import Node
async def spin(node: Node):
cancel = node.create_guard_condition(lambda: None)
def _spin(node: Node,
future: asyncio.Future,
event_loop: asyncio.AbstractEventLoop):
while not future.cancelled():
rclpy.spin_once(node)
if not future.cancelled():
event_loop.call_soon_threadsafe(future.set_result, None)
event_loop = asyncio.get_event_loop()
spin_task = event_loop.create_future()
spin_thread = threading.Thread(target=_spin, args=(node, spin_task, event_loop))
spin_thread.start()
try:
await spin_task
except asyncio.CancelledError:
cancel.trigger()
spin_thread.join()
node.destroy_guard_condition(cancel)
This code can then be used, for example, like this:
async def main():
# create a node without any work to do
node = Node('unused')
# create tasks for spinning and sleeping
spin_task = asyncio.get_event_loop().create_task(spin(node))
sleep_task = asyncio.get_event_loop().create_task(asyncio.sleep(5.0))
# concurrently execute both tasks
await asyncio.wait([spin_task, sleep_task], return_when=asyncio.FIRST_COMPLETED)
# cancel tasks
if spin_task.cancel():
await spin_task
if sleep_task.cancel():
await sleep_task
# run program
rclpy.init()
asyncio.get_event_loop().run_until_complete(main())
asyncio.get_event_loop().close()
rclpy.shutdown()
