I am using two instances of ROS robot_localization package to get the local and global odometry. In the local one, I am fusing IMU and twist messages. It is working fine. But when I use the second instance where map and odom frame both should be fixed points, one of them is moving. I set map as the fixed frame, then odom is moving. Why is that? Odom should remain fixed at the initial starting point. base_link with respect to odom is working fine but since odom is moving, base_link with respect to map is not working.
In the image, you can see the map frame is the big axes. odom frame was there too. But as I move the robot, the odom frame starts moving. The red lines are local odometry and green ones are global odometry.
enter image description here 1st instance:
ekf_se_odom: # Used only for broadcasting odom to base_link transforms
  frequency: 30
  sensor_timeout: 0.1
  two_d_mode: true
  transform_time_offset: 0.0
  transform_timeout: 0.0
  print_diagnostics: true
  debug: false
  map_frame: map
  odom_frame: odom
  base_link_frame: base_link
  world_frame: odom
2nd instance:
ekf_se_map:
  frequency: 30
  sensor_timeout: 0.1
  two_d_mode: true
  debug: false
  map_frame: map
  odom_frame: odom
  world_frame: map
  publish_tf: true
navsat_node:
navsat_transform:
  frequency: 30
  delay: 3.0
  magnetic_declination_radians: 0.0842
  yaw_offset: -1.57080
  zero_altitude: true
  broadcast_utm_transform: true
  publish_filtered_gps: true
  use_odometry_yaw: false
  wait_for_datum: false
  broadcast_utm_transform_as_parent_frame: false
I am using gazebo husky simulation.
  • $\begingroup$ Are you sure, you do not have other nodes running in the background? Using Ctrl + C does stop the stop but sometimes, it runs in the background. $\endgroup$
    – Dave
    Dec 30, 2022 at 11:25
This assumption is not correct, as map->odom is allowed to change. You have configured your 2nd instance to publish this update.
An update to the map->odom TF is typically done to correct for drift in odom->base_link since it comes from an odometry source.
The purpose of this to make the overall transform map->base_link a globally accurate source for localisation and mapping purpose which may have discontinuous jumps (e.g. Due to loop closure from SLAM), while maintaining odom->base_link as an approximately accurate but more importantly continuously varying TF for control and state estimation purposes.
The purpose of this structure is formalised and documented in REP-105
