I am attempting to teach myself sensor fusion as I suspect I'll need to do this down the road with lidar and some other sensors. In all my research so far it sounds like a version of the extended kalman-filter is the best way to do this.
I believe I have a good intuition for how the EKF works but I am stuck on a few things. First let me describe my understanding of the process in general.
  1. Starting at time $k_1$, use a motion model to predict the pose of the vehicle at time $k$
  2. Use a measurement model to describe where we can expect the measurement to occur
  3. Once a measurement is observed we use step 3 to decide how much of the measurement should be used to update the predicted state
  4. Update the predicted state with information from step 3.
  5. Repeat forever
What I am really stuck on is how do we measure the pose of the robot with a sensor like lidar or radar? Several examples I have found show the raw lidar data as if it were the measured pose of the robot, instead of the distance from a object. They use this raw data in step 4 above but this doesn't make sense to me. How can we get a better prediction of the state using the raw lidar data if we can't actually measure the state of the robot using the lidar?
One common way of using LiDAR to estimate the pose of a robot is by scan-matching against a previously-created occupancy grid (map), then using the match scores in a pose estimation system like AMCL. Then, that pose estimate is often fed into an EKF, along with other state measurements (wheel odometry, IMU), to "fuse" them all together to form a filtered pose estimate. If you Google terms like "AMCL" and "scan-matcher", you'll find a wealth of literature and tutorials about using LiDAR for this purpose.
