The title says it all. I would like to have object that the rangeFinder can't see. This would help me to model real life shiny objects for a ToF sensor in webots. Any suggestions?
1 Answer
You can set the visibility of nodes w.r.t. rendering devices (Camera, Lidar, RangeFinder or Viewpoint) using the Supervisor function wb_supervisor_node_set_visibility
If your robot equipped with the RangeFinder has supervisor
functionalities (i.e. the Robot.supervisor
field is set to TRUE) you can simply set the objects visibility directly in the robot controller.
Otherwise, you might need to add an empty Robot node in your world, with supervisor
field set to TRUE, that sets the nodes visibility at the very beginning of the simulation.
Here is a sample python controller to set the visibility that retrieves both the object and RangeFinder nodes using the DEF name:
from controller import Supervisor
supervisor = Supervisor()
range_finder = supervisor.getFromDef("RANGE_FINDER")
hidden_object= supervisor.getFromDef("HIDDEN_OBJECT")
hidden_object.setVisibility(range_finder, False)
Disclaimer: I'm part of the Webots development team.
