When I try to create a vector of message_filters::Subscriber like so:
#include <message_filters/subscriber.h>
#include "sensor_msgs/msg/point_cloud2.hpp"
int main(int argc, char * argv[]) {
std::vector<message_filters::Subscriber<sensor_msgs::msg::PointCloud2>> pc_subscribers_;
message_filters::Subscriber<sensor_msgs::msg::PointCloud2> sub;
pc_subscribers_.push_back(sub);
return 0;
I get the following error:
/home/sam/work/radar_ws/src/radar_velocity_cpp/src/publisher_radar_ego_comp.cpp:56:31: required from here
/usr/include/c++/9/ext/new_allocator.h:146:4: error: use of deleted function ‘message_filters::Subscriber<sensor_msgs::msg::PointCloud2_<std::allocator<void> > >::Subscriber(const message_filters::Subscriber<sensor_msgs::msg::PointCloud2_<std::allocator<void> > >&)’
146 | { ::new((void *)__p) _Up(std::forward<_Args>(__args)...); }
In file included from /home/sam/work/radar_ws/src/radar_velocity_cpp/src/publisher_radar_ego_comp.cpp:3:
/opt/ros/foxy/include/message_filters/subscriber.h:102:7: note: ‘message_filters::Subscriber<sensor_msgs::msg::PointCloud2_<std::allocator<void> > >::Subscriber(const message_filters::Subscriber<sensor_msgs::msg::PointCloud2_<std::allocator<void> > >&)’ is implicitly deleted because the default definition would be ill-formed:
102 | class Subscriber : public SubscriberBase, public SimpleFilter<M>
